Port 5600 closed
deeross1974
Port 5600 closed
Hi I need port 5600 open for my CCTV
ive tried everything to open it but my router will just not allow it
can anyone help me
18 REPLIES 18
deeross1974
Re: Port 5600 closed
sorry port 56000
Fixes: 1,483
can you give some useful info such as make / model of your router and what steps you have already tried?
deeross1974
Hi my router is as follows
1 - Product name: Plusnet Router
2 - Serial number: N7151791M003813
3 - Firmware version: 7.275.2_F2704N_Plusnet
4 - Board version: F@ST2704N
Blocked loads of ports then tested them on port checker they are still saying closed
deeross1974
only available port is 80
alanf
Anything to do with Plusnet Broadband Firewall settings?
deeross1974
Hi paul no ive unblocked everything temporarily even on the router turned off fire walls just to try to get this port open
alanf
Paul?
deeross1974
Alan? lol
Alan!, Alan!, Alan! ... Steve!, Steve!, Steve!  Grin
To eliminate the possibility that perhaps either the Plusnet network, or Plusnet "Broadband Firewall" was inadvertently blocking these ports,  I've just run the GRC "ShieldsUP!" remote port scan, and I can confirm that my router firewall captured both TCP ports 5600 and 56000 being probed, with the Plusnet "Broadband Firewall" set to "Low".
So it looks like you need a Plusnet router expert, to guide you on how to configure port forwards. Cry
Good luck with that !  Undecided
deeross1974
this dont look good see attached
Do you want to PM me your IP address (http://www.whatsmyip.org/), and I will tell you what appears on your TCP port 80 ?
deeross1974
Would this have something to do with the Ethernet Extender am running through?
deeross1974
gonna buy a new router as this garbage router cant do nothing
plus i cant even assign a ip address to a device
can anyone suggest a decent router that will work with plusnet modem?
No, it's not going to be the "Ethernet Extender"
The ShieldsUP! report is indicating that TCP port 80 (i.e. the http web interface) of your network is exposed and responding to unsolicited requests from ANYONE on the internet.
It is most likely displaying the web login screen of your router (where you type your username and password to get to it's settings).  Alternatively if you have a port forward already set up, then the web interface of the device (to which the port is forwarded) will be accessible to anyone on the internet.
Either way, having port-80 respond like that, means that anyone performing a remote port probe looking for networks to access, will know that you are there and responding.
