Poppy, I need technical help please.
- Poppy, I need technical help please.
- « Previous
- 1
- 2
- Next »
Re: Poppy, I need technical help please.
14-08-2009 5:09 PM
Sorted - thanks for that.
14-08-2009 7:08 PM
Actually, another way (at least in Ubuntu 9.04) is System \ Preferences\ "Startup Applications" to control what starts up after login.
14-08-2009 8:06 PM
I was going to install the other version but decided to have a fiddle about first.
After a bit of trial and error I did this:-
System -> Preferences -> Sessions - > Startup Programs ->Add
I put AWN on the Name field and avant-window-navigator on the Command field.
Restarted and AWN started up fine. Thanks for all the ideas
Edit: I am still on 8.10 and the option for Start up Application is not available
14-08-2009 9:30 PM
That's why I put the version number in - I had a vague recollection that the name & interface to the function had changed (a bit).
14-08-2009 9:31 PM
Quote from: Crucibleofevil Actually, another way (at least in Ubuntu 9.04) is System \ Preferences\ "Startup Applications" to control what starts up after login.
I said that in a previous post btw
Quote from: biker955 For others just add them to the Preferences/Startup manager!
- « Previous
- 1
- 2
- Next »
