Poor wireless connections after changing hard drive
Rourkefamily
Had to replace the hard drive on my Desktop. Installed no problem and reloaded all my programs.
Internet connected up straight away so did not reload drivers for Modem. Since then the my wireless connection to the lap top is poor. Will connect when first switched on and then connection is lost in about five minutes.
Any ideas?
Re: Poor wireless connections after changing hard drive
What modem what O/S how are you connecting to the laptop ie wireless card etc?
First guess is get the latest drivers as windows may have installed old drivers
Rourkefamily
Modem is Netgear DG834G
Operating system is XP
Tried to reinstall the drivers and it prompts me for a password to an IP address I don't have a clus about  Huh
minkey
Do you have any other devices connecting to your wireless router? You need to make sure your Fragmentation threshold and RTS are the same on all wireless devices.
Jeff
Rourkefamily
Nothing change except a hard drive swap to the desktop where the router connects too
Your not making sense you said changed HD connected straight away so didnt reload MODEM DRIVERS.
If its a router were do modem drivers come into it as you dont have a modem?
Are you connecting from the pc with the new drive via a cable or wireless?
Rourkefamily
Installed new hard disk.
Reloaded 'My Documents' from the back up (Not anything else)
Then I was able to connect to the Internet straight away via the hard wired Netgear DG834G Modem Router. Also still able to connect my laptop wireless but lose connection after about five minutes and cannot reconnect.
I did not reload any drivers?
Desktop with new hard disk is hard wired.
VileReynard
Seasoned Pro
Fixes: 10
So the machine with the new disk and the machine with the wireless connection are different machines?
Rourkefamily
Yes!
VileReynard
Seasoned Pro
Fixes: 10
Quote from: Rourkefamily
Yes!
So how can a wired connection (on a different PC) affect a wireless connection on a lap top?
I assume the desktop doesn't have a wireless and a wired connection?
Rourkefamily
Quote from: axisofevil
That is why I am asking. Is it coinsidence? The Laptop connects daily to a Network at work so has something downloaded to change the ability to stay connected?
Desktop does not have wireless and is hard wired.
Reset the modem today and reloaded the drivers. Hard wired all OK. Wireless connect OK and five minutes later I lose the connection.
Maybe the correct question here is what would cause a wireless netwoork to lose a connection after Five minutes without you moving?  Huh
VileReynard
Seasoned Pro
Fixes: 10
It could be your network configuration.
For example do you use static addresses?
Does the wireless connection work if the desktop is kept switched off?
If not, you probably ought to post detailed network details.
