Poor VPN speeds using Private Internet Access
- Poor VPN speeds using Private Internet Access
12-02-2017 8:23 PM
I'm using private internet access with hub one , when I turn pia on I lose Wi-Fi . what am I doing wrong as I'm new to vpn . thanks
Re: Poor VPN speeds using Private Internet Access
12-02-2017 8:58 PM
12-02-2017 9:24 PM
13-02-2017 7:07 AM
Do you have on safeguard on?
13-02-2017 12:33 PM
Are you behind a firewall? Maybe that's what's blocking your connection 😕
13-02-2017 8:31 PM
thanks for the reply . I have just checked , I was but still have the same issue
13-02-2017 8:33 PM
thanks for the reply , my safeguard is set to low . yes the app goes green
14-02-2017 8:33 AM
tracert www.google.co.uk
