Poor VPN speeds using Private Internet Access
dave10
I'm using private internet access with hub one , when I turn pia on I lose Wi-Fi . what am I doing wrong as I'm new to vpn . thanks
7 REPLIES 7
Fixes: 1,483
Re: Poor VPN speeds using Private Internet Access
I use pia and haven't had any issues with the hub - are you using the pia app?
dave10
Yes I am . I'm using standard settings if that helps. Thanks
Fixes: 1,483
Assume the app goes green to show it is connected ok?
Do you have on safeguard on?
GeneralRAAM
Are you behind a firewall? Maybe that's what's blocking your connection 😕
dave10
thanks for the reply . I have just checked , I was but still have the same issue
dave10
thanks for the reply , my safeguard is set to low . yes the app goes green
Fixes: 1,483
can you open a command prompt (type cmd in the search box) and give the results of the following command:
tracert www.google.co.uk
