PlusnetAssist installation problem
cromfield
I tried to install PN Assist.  Downloaded the exe file OK but shortly after trying to install it I but got a pop up message "Installation failed - unable to complete installation".
This happened a couple of times and I don't know what to try next. (It installed OK on my wife's laptop)
Anybody got any suggestions?
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: PlusnetAssist installation problem
Hi cromfield,
What version of Windows are you using?
Chris Pettitt
Cloud Environments Engineer
cromfield
Hi Chris,
Using Vista, but I've managed to install PN Assist now.
Realised I was having a problem with some other web pages as well so I uninstalled my browsers (Chrome and Firefox) the re-installed them. Now seems to be OK. I don't know how the problem occurred though.
Thanks for responding to my post.
Regards,
Dave
Plusnet Staff
Plusnet Staff
Fixes: 5
I'm glad you managed to get that sorted out Smiley
Chris Pettitt
