Plusnet router issue
- Re: Plusnet router issue
05-01-2016 7:10 PM
05-01-2016 7:12 PM
05-01-2016 7:15 PM
05-01-2016 7:18 PM
05-01-2016 7:21 PM
05-01-2016 7:25 PM
05-01-2016 7:28 PM
05-01-2016 7:33 PM
05-01-2016 7:46 PM
05-01-2016 7:47 PM
05-01-2016 7:56 PM
05-01-2016 7:58 PM
also when you say you can't get in, is that to the router settings or the DSL connection? if it's the router login page please can you factory reset the router(there's a pinhole on the back), once that's done try getting in using the Admin/Serial Number details, then manually input the broadband connection settings once in the router
05-01-2016 8:49 PM
05-01-2016 8:53 PM
I'll be back in the office at 11:30 tomorrow to check things once more if that doesn't get you connected
06-01-2016 11:27 AM
Just had a quick check on things and RADIUS is showing an active connection
Glad things are working once more
