Plusnet protect
- Plusnet protect
Plusnet protect
20-01-2014 9:12 AM
Does Plusnet protect powered by McAfee work on Windows 8.1?
4 REPLIES 4
Re: Plusnet protect
20-01-2014 12:55 PM
I have heard people that have managed to get it working on Windows 8.1 and it is on our list of supported Operating Systems, So in theory it should work!
you can download here via the members centre - https://portal.plus.net/McAfee/downloads.html
Re: Plusnet protect
20-01-2014 1:08 PM
David - all Plusnet staff are supposed to have a proper setup and Postion set (that gives them the Plusnet logo). If you really do work for Plusnet I suggest you contact the Digital care team urgently to get yourself properly set up.
Re: Plusnet protect
20-01-2014 1:16 PM
That has been done now, I was just posting while that was in the process of being changed
Re: Plusnet protect
20-01-2014 2:48 PM
i have already downloaded the software but i was wondering if i update my laptop to Windows 8.1 will plusnet protect still work?
