Plusnet issued Sagem 2704n Router - will it work with Talk Talk
- Re: Plusnet issued Sagem 2704n Router - will it w...
19-02-2016 7:17 PM
Re: Plusnet issued Sagem 2704n Router - will it work with Talk Talk
21-02-2016 12:10 AM
Are you on Fibre Optics or ADSL?
22-02-2016 1:12 AM
I am on basic broadband, not Fibre Optic.
22-02-2016 6:02 PM
22-02-2016 6:12 PM
TalkTalk may not require connection login details as they authenticate routers differently. However if they do require details, they can be found by contacting TalkTalk.
NE
23-02-2016 10:33 PM
You said "clear the username / password (connection details) off the current plus net router. You could factory reset it"
How do I clear the password/username?
I see the reset pinhole on the back of the router so by pressing that will it work on Talk Talk without further ado.
24-02-2016 5:42 PM
However try resetting it and it may work.
NE
24-02-2016 5:55 PM
You will need to enter your TT details rather than the PN ones.
24-02-2016 9:19 PM
Quote from: NorthEasterner Unfortunately I don't have the older Plusnet router to hand since I only have the Hub One.
NE
Thanks, that would be the simplest way - if it works.
24-02-2016 9:30 PM
Quote from: Mustrum Details on how to set up the Sagem can be found on the Help Pages Here.
Mustrum, thanks for the link. It looks fine. I know it was simple to do when I set up Plusnet broadband but I did not know if using a Plusnet router to connect to Talk Talk broadband would be a problem. If all else fails, a factory reset will be my option..
