Plusnet icon
gleneagles
Aspiring Legend
Fixes: 17
Plusnet icon
I feel a bit daft asking this but how do you put a plusnet icon on a tablet ?
Wiped everything of my tablet to get rid of all the clutter and rubbish, downloaded all the apps I previously used with no problem and saved them.
All those icons are showing and working but can't get the PN one ?
We are born into history and history is born into us.
6 REPLIES 6
Fixes: 1,495
Re: Plusnet icon
what did this icon do?
gleneagles
Aspiring Legend
Fixes: 17
Re: Plusnet icon
Well I just touched it and it took me to the login page of the member centre.
gleneagles
Aspiring Legend
Fixes: 17
Re: Plusnet icon
To access plus net now I need to type it into a search engine and access it that way
Fixes: 1,495
Re: Plusnet icon
so it's basically a shortcut to the webpage then?
which tablet is it?
gleneagles
Aspiring Legend
Fixes: 17
Re: Plusnet icon
Samsung tab S 10.5
First generation
Fixes: 585
Re: Plusnet icon
@gleneagles This https://www.howtogeek.com/196087/how-to-add-websites-to-the-home-screen-on-any-smartphone-or-tablet/ should help
