Plusnet disconnecting from Samsung
yviej
Interested
Hi i'm kind of new to technology and i'm not sure if this is the right place to go to.
I have a Samsung S4 that used to connect to my router with no problems but recently it keeps disconnecting after 2-5 minutes. I keep getting notifications such as "Your device has been disconnected from this network. Your session has timed out" and "Sign in is required" after opening my browser to sign in. I've been having this trouble for 3 days and cannot find anything online to help, i even checked my hub manager and still nothing.
Does anyone have a solution to this?
1 REPLY 1
VileReynard
Fixes: 20
Re: Plusnet disconnecting from Samsung
A Samsung S4 is a mobile phone - are you referring to using the wifi on the router as a data connection?
There ought to be a setting on the S4 for "internet always on" or similar name.
