Plusnet assist
gleneagles
Aspiring Legend
Fixes: 17
Plusnet assist
Can some one give me exact instructions for removing Plusnet assist from a Laptop running windows 7.
We are born into history and history is born into us.
4 REPLIES 4
Fixes: 1,483
Re: Plusnet assist
format c:
Roll_eyes
Oldjim
Resting Legend
Fixes: 63
Re: Plusnet assist
Typical helpful response from a Mac user  Shocked
This is from when I was testing it before release
Window 7 64 bit
Tried uninstalling from Control Panel - didn't work as it is the wrong executable
Uninstalled from the start menu worked and all the addons seem to have gone.
The Motive folder has gone but the Plusnet Assist hasn't gone but is empty
Note that it claimed a reboot was needed
computing50yrs
Re: Plusnet assist
Just go to Control Panel then programs & features , go down program list to find Plusnet assist and uninstal it.
Its not taking up much space and you can always remove the desktop Icon if you don't want to see it
gleneagles
Aspiring Legend
Fixes: 17
Re: Plusnet assist
Thank you.
I Was just a bit bothered it might have integrated with something else resulting in additional problems.
Removed as suggested.  Smiley
