Plusnet assist
- Re: Plusnet assist
Plusnet assist
18-11-2012 2:39 PM
Can some one give me exact instructions for removing Plusnet assist from a Laptop running windows 7.
We are born into history and history is born into us.
4 REPLIES 4
Re: Plusnet assist
18-11-2012 2:55 PM
format c:
Re: Plusnet assist
18-11-2012 5:04 PM
Typical helpful response from a Mac user
This is from when I was testing it before release
Quote Window 7 64 bit
Tried uninstalling from Control Panel - didn't work as it is the wrong executable
Uninstalled from the start menu worked and all the addons seem to have gone.
The Motive folder has gone but the Plusnet Assist hasn't gone but is empty
Note that it claimed a reboot was needed
Re: Plusnet assist
25-11-2012 1:33 PM
Just go to Control Panel then programs & features , go down program list to find Plusnet assist and uninstal it.
Its not taking up much space and you can always remove the desktop Icon if you don't want to see it
Re: Plusnet assist
25-11-2012 4:20 PM
Thank you.
I Was just a bit bothered it might have integrated with something else resulting in additional problems.
Removed as suggested.
