Plusnet assist Hyperlink (Javascript) not working
- Plusnet assist Hyperlink (Javascript) not working
11-04-2013 8:50 PM
HI Gang
I think I am having a senior moment. I am attempting to run Plusnet assist in IE 10 and none of the Javascript links work. Iam running in a Windows 7 64bit environment.
Have tried googling for help with no avail.
Help please
Help please
4 REPLIES 4
Re: Plusnet assist Hyperlink (Javascript) not working
11-04-2013 10:41 PM
Is Javascript allowed to run on Internet Explorer v10 ?
You may need to give Javascript permission to run
13-04-2013 2:23 PM
I'm in the same boat as Johnivor. Just installed Assist. None of the links work. I have enabled scripting in the Security tab of IE10 as well as Java applets. Does anyone have an answer?
13-04-2013 3:30 PM
Try viewing it in compatibility mode?
See: http://blogs.technet.com/b/ewan/archive/2012/08/17/tip-o-the-week-132-tweaking-ie10-compatibility.as...
15-04-2013 2:00 PM
Thank you. That works.
