Plusnet Unprotect./Mcafee are on something.
- Plusnet Unprotect./Mcafee are on something.
27-06-2014 12:41 PM
Utorrent... - where viruses are free.
My PC does not need an illegal virus ridden program on it.
Ave a word
Re: Plusnet Unprotect./Mcafee are on something.
27-06-2014 12:46 PM
I'm confused?
27-06-2014 12:47 PM
From my experience Vulnerability Scanners only update programs which are already there and don't install new ones
27-06-2014 12:56 PM
http://download.mcafee.com/products/webhelp/5/2057/index.html#GUID-C2DB8127-EF4D-42D3-9652-3882878A5...
Quote With Vulnerability Scanner, you no longer have to wait to be notified when a Windows or program update is available. Vulnerability Scanner finds them first and installs them.
Here's how it works:
1 Vulnerability Scanner first checks for potential security issues in your Windows files and installed programs.
2 It then scans for software updates to repair any vulnerable Windows files and programs, and provides a detailed scan report that shows the number of updates found, and a description of each update.
3 Depending on the type of scan you run, Vulnerability Scanner can automatically install all updates, or you can select the updates you want installed.
4 Finally, Vulnerability Scanner provides a summary of installed or incomplete updates, and lets you know if there are additional updates that you need to install yourself.
Regards
Mike
27-06-2014 12:58 PM
If you do not want to keep the Utorrent
Uninstall it using revo uninstaller free version, to remove all traces of it
Then reboot machine
Then run McAfee's (Vulnerability scanner) again
27-06-2014 1:12 PM
27-06-2014 1:17 PM
And no I've never had it before.
27-06-2014 1:32 PM
27-06-2014 4:54 PM
Unchecky.com
Regards
Mike
28-06-2014 2:49 AM
The main things are common sense & eliminating distractions from pets / children / other adults, not rushing to install the software etc, so that one can pay attention to what they are installing.
Before installing any software especially if one has never used it before, Research it, read up on it & understand it before deploying it on the PC / Device etc
Also one needs to pay attention to where one downloads the software that they want to install, (ALWAYS OBTAIN it from the manufactures website (WHERE POSSIBLE), even then they may use mirror sites, & or software bundles, especially for free(ware) software.
Would you buy a car without checking under the hood ?
28-06-2014 12:47 PM
The big problem with installing computer software is that many install processes are design to trap the unwary to installing something they did not want / need. Java / Adobe / Flash are particularly bad at all too unobviously by default installing browser add-ins or in extreme cases unwanted deficient new browsers (Chrome).
On many download sites, the big DOWNLOAD button next to the software you've found / want does not download the software, but downloads a downloader containing God only knows what!
28-06-2014 1:51 PM
28-06-2014 5:23 PM
28-06-2014 6:01 PM
You defend it all you want, it was shit back then it's shit now and I will just uninstall it - it's clearly Mccrappee and just a virus downloading viruses.
28-06-2014 6:07 PM
Quote from: petecov44 Vulnerability scanner just installed Flash player for IE and Utorrent 3.4.2
FACT: It would not have done that unless you already had them on your PC, probably installed without your knowledge when installing some other piece of software.
You can believe what you like, but for the sake of others visiting these forums, incorrect information needs to be corrected.
