Plusnet Security fails to install
melsajs
I get to 83% installed then get the message 'the following component failed to install - SecurityCenter'.  have tried using the McAfee pre load software and switching off Windows Defender software and Firewall plus Core protection but nothing seems to work.  Windows is up todate
2 REPLIES 2
shutter
Fixes: 64
Re: Plusnet Security fails to install
I used to run various anti-virus progs for many years.. however, for the past 3 years, I have relied on Windows Security Essentials   ( aka windows defender )... I have not had any virus attacks,  so will not be going back to "third party" anti-virus progs...
Unless you are going to visit dodgy sites, and click on unknown links in emails, I would recommend you forget about McAfee and all those others... and rely on the Windows Anti-virus .
Fixes: 1,481
Moderators Note
This topic has been locked in favour of  https://community.plus.net/t5/Everything-else/McAfee-not-loading/m-p/1594541#M20496
