Plusnet Protect and Windows 10 v1607
- Plusnet Protect and Windows 10 v1607
15-10-2016 8:31 AM
My PC recently installed the window 10 upgrade v1607. I am now receiving message saying that my MacAfee Anti-Virus (version 19.0.161) protection via PlusNet Protect (version 14.0) is non-compatible with the new version of windows.
Has anyone else experienced this issue and how to fix it?
Thanks for any help.
Re: Plusnet Protect and Windows 10 v1607
21-10-2016 8:42 AM
'Plusnet Protect' is not popular on this section of the Forum so you may not find anyone else using it who might have experienced the same issue. On Windows 10 I personally think you are much better off using the built-in security software 'Windows Defender' than using a McAfee product.
21-10-2016 11:12 AM
The best way to fix PlusNet Protect ,,,,,,, Remove IT
22-10-2016 1:23 AM
As above, the included internet security package in Win10/8/7 is far superior than a dated build of McAfee.
