Plusnet Modem....frequency
gleneagles
Aspiring Legend
Fixes: 17
I use a PN modem for fibre broadband but does anyone know what frequency it works on.
The reason I wish to know is that I have tried pairing it with a TP smart plug which clearly states it only works on the 2.4 band.
I understand there may be a option to change to a alternative band but as everything currently works ok would rather return the plug than experiment.
I have downloaded the recommended KASA app for the plug.
We are born into history and history is born into us.
3 REPLIES 3
shutter
Fixes: 64
Re: Plusnet Modem....frequency
@gleneagles Download and install   Inssider    .... free stuff... you will see all available wifi within about 100 yards... the channel they are on... and the frequency band they use..  ( I think the latest version has separate pages or graphs,  for 2.4 and 5. bands )
Marksfish
Seasoned Pro
Fixes: 4
The PN router has both 2.4 and 5ghz bands. If you separate them, you can connect your home plug to the 2.4 network.
Mark
Alex
Fixes: 13
Yep as @Marksfish said it will use both with the same SSID, which may cause problems if you're using equipment which only works on 2.4Ghz.
There is a setting on the Hub One for example to split them into two SSID's - so you can name them something like WhateverYouWant-2.4 and WhateverYouWant-5. Tell the home plugs to use WhateverYouWant-2.4 which you know only uses 2.4 and the plugs won't try to switch to 5Ghz and stop working.
Sounds like a split is the way to go.
