Plusnet Hub One streaming?
OhWell
Hi all,
Question for the tech gurus;
I see the Plusnet Hub One has a USB port on the back.
Is it possible to plug an external drive with movies etc into the router, and then play this media on my Fire 4k stick plugged into my TV via the WiFi network?
1 REPLY 1
OhWell
Re: Plusnet Hub One streaming?
For anyone I interested, I connected a usb stick with media on it into the Plusnet Hub One, and installed VLC on my Fire 4K Stick.
It found the media and played ok, so problem solved!
