Plusnet FFTP setup for TPlink Vr2800
- Plusnet FFTP setup for TPlink Vr2800
- « Previous
- 1
- 2
- Next »
Re: Plusnet FFTP setup for TPlink Vr2800
26-04-2023 8:39 PM
Hello going to add one extra tip to this useful thread. Had full fibre fitted today and installer said just move the existing cable into the ONT. No that's not what you have to do... DSL cable is no longer the right one, you're using the other type for devices into WAN4.
07-10-2023 7:59 PM
Ok just transferred from using ADSL to Full Fibre and thought I'd provide information on the transfer.
Step 1 - Unplug port from ADSL modem.
Step 2 - Using tether app login to Router and select Tools
Then change Operation mode.
Change from ADSL modem to Wireless Router. You will need Router to reload to enable.
Step 3 Enter User credentials
[email protected]
Login Password.
Plug in!
[email protected]
Login Password.
Plug in!
- « Previous
- 1
- 2
- Next »
