Plusnet FFTP setup for TPlink Vr2800
pantsman28
Getting FFTP full fibre installed tomorrow and not 100% of the configuration needed in the VR2800 for it to work?
Anyone got experience of the configuration setup?
I understand a cat 6 between BT Terminal and WAN port on router. not sure internet connection type or VLAN Id number?
16 REPLIES 16
Fixes: 587
Re: Plusnet FFTP setup for TPlink Vr2800
Internet connection PPPoE, vlan ID disabled
infinite
touch wood get mine turned (FTTC) on tomorrow as well... as far as I know you only need:
[email protected]
PPPoE
will let you know if anything different, as I to am using a Tp-link AC2800 (Archer VR2800)...
Fixes: 587
@infinite  for FTTC you will also need vlan ID set to  101
midnite
I have a TPLink Archer VR2800. I have upgraded to full fibre today and am trying to get my router to work with full fibre rather than using the one supplied by Plusnet. I have done the following things and I'm facing no internet connectivity;
Set the operation mode from DSL modem router mode to Wireless Router Mode (I did this because it was expecting me to connect to a phone line which I no longer have)
Connection type:  PPPoE
Username and password same as works on the new plusnet router.
Vlan ID to 101
However, it will not connect. Any ideas?
Fixes: 392
@midnite VLAN ID is 'none' - it is not used with a Full Fibre connection.
shutter
Fixes: 67
@midnite
From a google search.. " Does  The Archer VR2800 work with fibre broadband".
The Archer VR2800 has one DSL port and 4 ethernet ports, but no fibre port, to make it work, you need buy a fibre modem, so that we can connect it to the fibre cable provided by ISP and connect the modem to VR2800 and get internet.
Fixes: 392
Thanks @shutter . Although, AFAIK, the ONT is a 'modem'.
midnite
I'm happy to get a new router etc. What do I need to look for in terms of it supporting full fibre.
Would something like this https://www.amazon.co.uk/dp/B08C3VRM6M work? It has the lan2/p6 port on there which I believe is necessary.
Thanks in advance
Fixes: 392
@midnite I would wait for @MisterW or one of the other Community members who understand FF to respond before you take any action.
Fixes: 587
and here he is!
@midnite The vr2800 should work fine in wireless router mode. Connect the ONT to lan port 4 (wan port ) configure pppoe and as@jab1  says , disable vlan id
If it doesn't work then try a factory reset and start by setting wireless router mode first.
midnite
For clarification what is ONT?
Fixes: 392
The white box BT will have installed in place of your master socket.
Fixes: 587
Optical Network Termination
midnite
Thanks everyone for your help. Managed to get it all set up.
