Plusnet Email Redirect
mrmarkus1981
Trying to set this up in email settings to forward all plusnet email to my own domain but get this message
The name mark is already in use or is a reserved name. Please select another.
Any ideas?
Fixes: 183
Re: Plusnet Email Redirect
You can't redirect on an existing mailbox, which I assume you are trying to do?
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
mrmarkus1981
Yeah i'm trying to get ALL email sent to me at my plusnet address to go elsewhere
I take it this cannot be done?
Fixes: 183
Not that I'm aware of, I use Gmail to retrieve my mail from other mail boxes. Works well for me.
mrmarkus1981
Thanks adiewoo, done something similar with my new email provider which now catches plusnet email
thanks again  Smiley
Fixes: 183
No worries, it's a shame you can't do a redirect on an existing mailbox. You can with my domain host.
