Plusnet Assist
Javert
Plusnet Assist
Tried to download this earlier - and get the message: “This file couldn’t be downloaded”.  I have W7 - and use IE9 (email: Windows Live Mail).  I then disabled Kaspersky and tried again - with the same result.
I have looked through the FAQs for this - but cannot see anything there that might help.
Any advice please?
Fixes: 62
Re: Plusnet Assist
I am running W7 64 bit with Kaspersky and going to here http://www.plus.net/assist/ and selecting Download on IE9 I get this (first pic) and selecting Save it downloads this (second pic)
Javert
Re: Plusnet Assist
Have taken a screen shot of that download page (Sorry, I don’t know how to post images on here) - mine reads:
PlusnetAssistInsta... 629KB This file couldn’t be downloaded.
pbttbcpn.bt.motive.com
There is a retry button - which I’ve clicked on - but to no avail.
I’ve gone to the link you provided and clicked to download - but the same message appears - that it cannot be downloaded!  It’s one of those little computer bugs!
Unfortunately, this is a “brick wall” and I’ve no idea how to progress beyond it.  So, I’ll admit defeat and abandon the project.  Thanks for your help.
Fixes: 62
Re: Plusnet Assist
Probably as well.
I tried it during the testing phase and I wasn't impressed.
It is really only of use to the technically challenged
Fixes: 10
Re: Plusnet Assist
Quote from: Javert
That was lucky. If you'd succeeded in downloading it you might have been tempted to use it!
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Fixes: 10
Re: Plusnet Assist
Quote from: Javert
Open up the Additional Options and Attachments... below where you compose your post.
Javert
Re: Plusnet Assist
Quote from: jelv
Very true!  Grin
Fixes: 103
Re: Plusnet Assist
Quote from: Javert
Any advice please?
I'd warrant a guess that something is blocking Active X. You can check these settings under Internet Options > Security Tab > Custom Level.
Javert
Re: Plusnet Assist
Thanks for reply - I took a look at the area you suggested but - I'm really out of my depth on such things.  I'm going to give PlusNet Assist as I don't think it's something that I'd actually need.
