Plusnet Assist
francklavie
Plusnet Assist
Hi
I have tried to use the Plusnet Assist but it s telling me that I am not using the right browser. It needs at least IE 6 or newer version. My IE is 11 so surely it should be ok.
Not really sure what to do. Could you help, please?
Just bear in mind that I am not a techy guy 😉
Franck
4 REPLIES 4
Fixes: 1,481
Re: Plusnet Assist
best thing to do is uninstall it, it's pointless anyway.
Oldjim
Fixes: 63
Re: Plusnet Assist
It is, and I have said this since it was first introduced, a complete waste of space
The link to it http://www.plus.net/home-broadband/assist/ states
Operating system: Windows 7 (32 bit and 64 bit). Windows Vista (32 bit and 64 bit). Windows XP (32 bit with SP2). Processor type: Pentium II or higher. Processor speed: 450 MHz or higher. Memory (RAM): 128 MB or more. Hard drive space free: 200 MB or more. Browser: Internet Explorer only (up to version 9)
Plusnet Assist is not currently compatible with Windows 8 or Internet Explorer versions 10 and above.
jelv
Fixes: 10
Re: Plusnet Assist
Post to say what problem you were hoping to solve and we should be able to tell you how to do it without using Plusnet Assist.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
francklavie
Re: Plusnet Assist
Thanks to all! Will get rid....
