Plusnet Assist
mikesang
Plusnet Assist
I have tried to run Plusnet Assist on several occasions, after downloading it to my Windows 7 64bit PC.. It keeps giving me the message that I need to be using Firefox or Internet Explorer to run it.  I use Firefox but the program does not recognise it, for some reason.
Is Plusnet Assist worth bothering about and what am I doing wrong ?
2 REPLIES 2
Fixes: 1,473
Re: Plusnet Assist
no it's not worth bothering with and it supports only certain versions. i'd give up if i were you...
jelv
Fixes: 10
Re: Plusnet Assist
There's absolutely nothing that PN Assist does that can't be done directly by a half competent user - forget it!
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
