Plusnet Assist
Steevo
Plusnet Assist
I keep getting Plusnet assist flashing up with script errors. I've tried uninstalling and reinstalling but now it won't even start without an error. Is there conflict with java/flash or something like that?
Current error reads:
An error has occurred in the script on this page
Line 20
Char 4
Error: Automation server can't create object
Code 0
URL file:///c:prog files/plusnet assist/btbb/start.html
Anybody able to help?
5 REPLIES 5
Oldjim
Fixes: 63
Re: Plusnet Assist
Do you really need it - I wouldn't touch it with a barge pole
Steevo
Re: Plusnet Assist
Also keep getting:
Stop running this script?
A script on this page is causing your web browser to run slowly. If this continues to run your computer might become unresponsive.
Anybody able to advise?
Pettitto
Fixes: 5
Re: Plusnet Assist
Out of interest, do you have the latest version of Java? https://www.java.com/en/download/installed.jsp
Steevo
Re: Plusnet Assist
Yes, software versions were the first thing i checked. Internet explorer, java, shockwave etc.
jelv
Fixes: 10
Re: Plusnet Assist
Plusnet Assist it not necessary - there is absolutely nothing it does that can't be done directly.
Uninstall Plusnet Assist and tell us what problem you are trying to solve and we'll advise you how to do it.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
