Plusnet Assist
- Plusnet Assist
Plusnet Assist
19-02-2014 6:21 PM
I keep getting Plusnet assist flashing up with script errors. I've tried uninstalling and reinstalling but now it won't even start without an error. Is there conflict with java/flash or something like that?
Current error reads:
An error has occurred in the script on this page
Line 20
Char 4
Error: Automation server can't create object
Code 0
URL file:///c:prog files/plusnet assist/btbb/start.html
Anybody able to help?
Line 20
Char 4
Code 0
5 REPLIES 5
Re: Plusnet Assist
19-02-2014 6:24 PM
Do you really need it - I wouldn't touch it with a barge pole
Re: Plusnet Assist
19-02-2014 7:09 PM
Also keep getting:
Stop running this script?
A script on this page is causing your web browser to run slowly. If this continues to run your computer might become unresponsive.
Anybody able to advise?
Re: Plusnet Assist
20-02-2014 11:29 AM
Out of interest, do you have the latest version of Java? https://www.java.com/en/download/installed.jsp
Re: Plusnet Assist
20-02-2014 12:58 PM
Yes, software versions were the first thing i checked. Internet explorer, java, shockwave etc.
Re: Plusnet Assist
20-02-2014 1:04 PM
Plusnet Assist it not necessary - there is absolutely nothing it does that can't be done directly.
Uninstall Plusnet Assist and tell us what problem you are trying to solve and we'll advise you how to do it.
