Plusnet Assist not working
- Re: Plusnet Assist not working
12-09-2013 4:27 PM
I wanted to use PlusNet Assist. It fired up ok but none of the options work except 'online help'. They highlight ok but nothing happens when I click on them. I've tried uninstalling Assist and re-installing but still no good. Any ideas folks?
3 REPLIES 3
12-09-2013 8:55 PM
do a search on these forums
generally the view is dont load it its more trouble than its worth
If you have any problems you will get a better fix bringing to the willing experts who inhabit this web space
My experience of Assist was it reconfigured our e-mails for SWMBO so nothing worked. It only considers vanilla options and not some of the personalised set ups some of us have established.
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
12-09-2013 9:02 PM
Thanks Peter.
The odd thing is that it used to work fine and it was handy to have most things in one place. My setup is bog standard, nothing clever, so why it has stopped working is a mystery. The only thing I can think of is a Windows 7 update has scuppered it but that may be a red herring. It's no big deal but I'd rather it worked than not.
13-09-2013 12:27 PM
Plusnet Assist is a heavyweight piece of software for what should be a lightweight job. That probably makes it more prone to malfunction.
