Plusnet Assist not working
rovermorris999
I wanted to use PlusNet Assist. It fired up ok but none of the options work except 'online help'. They highlight ok but nothing happens when I click on them. I've tried uninstalling Assist and re-installing but still no good. Any ideas folks?
3 REPLIES 3
PeterLoftus
Fixes: 5
Re: Plusnet Assist not working
do a search on these forums
generally the view is dont load it its more trouble than its worth  Angry
If you have any problems you will get a better fix bringing to the willing experts who inhabit this web space  Roll_eyes
My experience of Assist was it reconfigured our e-mails for SWMBO so nothing worked. It only considers vanilla options and not some of the personalised set ups some of us have established.  Smiley
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
rovermorris999
Thanks Peter.
The odd thing is that it used to work fine and it was handy to have most things in one place. My setup is bog standard, nothing clever, so why it has stopped working is a mystery. The only thing I can think of is a Windows 7 update has scuppered it but that may be a red herring. It's no big deal but I'd rather it worked than not.
ReedRichards
Seasoned Pro
Fixes: 25
Plusnet Assist is a heavyweight piece of software for what should be a lightweight job.  That probably makes it more prone to malfunction.
