Plusnet Assist and Windows 8
Arfajob
As it's been nearly six months since the last reply to this subject, has there been any progress in enabling PlusNet Assist on PCs running Windows 8? I used it many times on my old PC to great effect, but I can't install it on my new one as it is not supported.  Cry
Come on PlusNet, get a wiggle on!  Kiss
1 REPLY 1
jelv
Fixes: 10
Re: Plusnet Assist and Windows 8
Could you tell us the things that Plusnet assist will do that you cannot do directly yourself (and without it changing things you don't want changed)?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
