Plusnet App upgrade fault
Ive just upgraded the Plusnet App on my iPod touch an it doesn't run! It closes immediately on opening Roll eyes
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
Fixes: 133
Re: Plusnet App upgrade fault
Out of interest did you uninstall the previous version and install the current one?
Customer and Forum Moderator.
No it was an update on the app store  Roll eyes
Fixes: 133
Peter the reason I asked is because of this regarding a similar issue.
Quote from: willas00
Delete the Application by holding your finger down on the app until it starts shaking and the icon has an X next to it at the top left.
Once deleted simply go to the AppStore and re-download it. This WILL fix the crash as it removes any stored feeds from the phone.
I have had something similar happen with this App and one of the PN staff passed it back to the author for a proper fix  Roll eyes
Bot thanks for the quick fix. I will give it a while to see if my post has similar results  Smiley
Fixes: 133
You could PM the author http://community.plus.net/forum/index.php?action=pm;sa=send;u=13339 Wink
...or email him willas00@gmail.com
