Plusnet App upgrade fault
- Re: Plusnet App upgrade fault
31-10-2011 10:57 PM
Ive just upgraded the Plusnet App on my iPod touch an it doesn't run! It closes immediately on opening
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
5 REPLIES 5
01-11-2011 12:01 AM
Out of interest did you uninstall the previous version and install the current one?
01-11-2011 7:14 AM
No it was an update on the app store
01-11-2011 11:23 AM
Peter the reason I asked is because of this regarding a similar issue.
Quote from: willas00 Delete the Application by holding your finger down on the app until it starts shaking and the icon has an X next to it at the top left.
Once deleted simply go to the AppStore and re-download it. This WILL fix the crash as it removes any stored feeds from the phone.
01-11-2011 12:20 PM
I have had something similar happen with this App and one of the PN staff passed it back to the author for a proper fix
Bot thanks for the quick fix. I will give it a while to see if my post has similar results
01-11-2011 12:23 PM
You could PM the author http://community.plus.net/forum/index.php?action=pm;sa=send;u=13339
...or email him willas00@gmail.com
