Plusnet 2704n Port Forwarding
benjp
I am trying to configure my 2704n router to forward traffic on port 3480 to a device on my network.
I have set up the device so that it always get the same IP address (192.168.0.5) from the router via the expert_user page.The routing only seems to work for a few minutes before the MAC address which the traffic is being forwarded to changes. This causes the routing to fail.
As suggested in several other threads I have disabled IPv6 in the router. I am however unable to configure the device (a VeraLite home automation box) to have a NETBOIS name so it it not "Unknown" in the interface; and I also have other "Unknown" devices in the network.
Does anybody have any hints to try and resolve the issue?
Many Thanks,
5 REPLIES 5
Anotherone
Champion
Fixes: 21
Re: Plusnet 2704n Port Forwarding
Is 192.168.0.5 a typo for 192.168.1.5? If not, it's probably failing because 192.168.0.5 is not within the DHCP pool.
benjp
No not a typo. The DHCP server is set to assign IP addresses in the range 192.168.0.2 - 254, so 192.168.0.5 is in my DHCP pool.
Anotherone
Champion
Fixes: 21
Did you see this post? That may help.
benjp
Thanks for posting, looks like the same issue!
The device I'm trying to forward to does not have samba installed, so as I understand it has no NetBIOS name; therefore the fix suggested in that post isn't possible.
Anotherone
Champion
Fixes: 21
Hmm, stumped for the moment. Forgot to say earlier, welcome to the forum by the way.
