PlusTalk (VoIP) and Linksys WIP300 IP Phone
- PlusTalk (VoIP) and Linksys WIP300 IP Phone
- « Previous
- 1
- 2
- Next »
Re: PlusTalk (VoIP) and Linksys WIP300 IP Phone
01-10-2007 2:15 PM
Quote I mentioned earlier that I have trouble even accessing the config page via my web browser
This implies its a faulty device, did you have this problem with an earlier firmware version or the previous phone?
02-10-2007 12:11 PM
Yes, my first phone had the same problems so I updated the firmware and bootcode but this made no difference and the replacement phone I'm now using came with the latest already loaded.
I thought I had made some slight progress, as I mentioned earlier I reset everything back to default (for which feels like for the hundredth time) and I was able to access the config page repeatedly. I then added my viop service data and I could still access the config page via the browser (IE7) yippee ! but call success rate still crap and after the phone had successfully registered a few times I'm now once again locked out !!, only by stripping out the viop service data can I once again access it god knows why this should be but I'm rapidly loosing patience with this thing. I think I'll pester Linksys yet again. They gave me a fault record number nearly 3 weeks ago then got the hump because I dared phone them for a progress update and was told don't call us we'll call you - what fantastic customer support that is !!
Paul
Paul
13-10-2007 1:19 AM
i got my linksys sip voip pap2-na to work without a stun setting and i did not forward any ports on my router
To get in to your phone setting you may have to turn off your anti-virus/firewalls until you have entered all the settings
Plusnet setting
Telephony Identity
SIP URI: enter sip id (numbers only)(found in account summary voip page)
Username: as above
Password: your password
Confirm Password:as above
Displayname: Blank
Abbreviated number: Blank
Port: port 1
Registrar sip.plus.net
Registrar Port 5060
Proxy sip.plus.net
Proxy port 5060
Expire Time 3600
United Kingdom Regional Settings:
Dial tone: 350@-19,440@-22;10(*/0/1+2)
Ring back: 400@-20,450@-20;*(.4/.2/1+2,.4/2/1+2)
Busy tone: 400@-20;10(.375/.375/1)
Reorder tone: 400@-20;10(*/0/1)
SIT 1 tone: 950@-16,1400@-16,1800@-16;20(.330/0/1,.330/0/2,.330/0/3,0/1/0)
MWI dial tone: 350@-19,440@-22;10(.75/.75/1+2)
CWT1 cadence: 30(.1/2)
CWT2 cadence: 30(.25/.25,.25/.25,.25/5)
CWT frequency: 400@-10
Ring 1 cadence: 60(.4/.2,.4/2)
Ring 2 cadence (BT Call Sign): 60(1/2)
Ring 3 cadence (BT Ring Back): 60(.25/.25,.25/.25,.25/1.75)
Ring 4 cadence: 60(.4/.8) 60(.four/.eight)
Ring 5 cadence: 60(2/4)
Time Zone: GMT
FXS Port Impedance: 370+620||310nF
Caller ID Method: ETSI FSK With PR(UK)
Daylight Saving Rule: start=3/-1/7/2:0:0;end=10/-1/7/2:0:0;save=1:0:0
Plusnet setting
Telephony Identity
Username: as above
Displayname: Blank
Port: port 1
Registrar Port 5060
Proxy sip.plus.net
Proxy port 5060
Expire Time 3600
Time Zone: GMT
- « Previous
- 1
- 2
- Next »
