PlusNet going to use Thompson routers ??????? are you mad.
- PlusNet going to use Thompson routers ??????? are ...
30-10-2008 11:51 PM
While im here i sould just like to say that AOL opperate the worst support system i have seen and their network is slow.
Strangly TALKTALK have got it right and pre program the routers b4 sending them out.. when will other suppliers follow suit..
If you guys start shipping thompson routers i think i will start using BT for home user clients..
MADNESS.
Re: PlusNet going to use Thompson routers ??????? are you mad.
30-10-2008 11:58 PM
31-10-2008 12:34 AM
31-10-2008 1:34 AM
31-10-2008 3:49 AM
Quote from: dorset3media As a I.T pro i set up customers BB daily, I have seen more issues with thompson speedtouch equipment than any others brand.
What sort of issues? Is there a common set of problems we should look out for?
31-10-2008 7:25 AM
Quote As a I.T pro i set
with typing like that not for very long then.
31-10-2008 7:43 AM
Quote from: dorset3media If you guys start shipping thompson routers i think i will start using BT for home user clients..
We're already shipping them and have been for a while. We've also got TR-69 firmware as we hope to start using this next year (which means we'll be able to configure the routers ourself at this end).
I'd be interested to hear of the problems you've encountered and in particular what models they affect?
31-10-2008 7:48 AM
Interesting that your going to recommend BT Home broadband (which comes with a Homehub which are made, IIRC by Thompson!)
Why not simply recommend a supplier based on service and suggest routers separately?
31-10-2008 8:04 AM
No disrespect to Plusnet (am an extremely happy customer) as am sure that the supplied routers are first class but I decided to use my own router after I had a one port router (not made by Thomson I might add and was supplied by another ISP) that used to get so extremely hot that I decided to switch it off when I wasn't using my connection for fear it might start a fire (it was stood on an end so that all the ventilation slots were clear but was on carpet because the router lives under my desk)
Seriously though, I wouldn't recommend anyone other than PN now
cp:quote
31-10-2008 12:01 PM
What's the issue?
Regards,
Neil
31-10-2008 1:50 PM
31-10-2008 1:58 PM
Only registered on the forum ten minutes before making the 1 post.........
31-10-2008 3:28 PM
Quote MADNESS.
31-10-2008 3:31 PM
Let's bring this back on topic, which to remind everyone is Thomson routers / PN's choice of hardware, not the credentials of the OP and his / her post.
Thank You
Daniel
31-10-2008 7:18 PM
In the days of dial up, no ISP used to provide a modem did they?
