Plus Net Wifi Connection problems after Sky Q Installation
- Plus Net Wifi Connection problems after Sky Q Inst...
03-05-2021 8:10 PM
Hello
Up until two weeks ago our Plus Net wifi (on Hub One) worked just fine. Following an upgrade to Sky Q including mini box, other devices in the house are dropping out. This is causing quite a bit of frustration. I can only assume its something to do with the Sky Q install. Not quite sure what to do. I am working at home for the NHS at the moment so reliable wifi is needed! Not sure whether this is a Plus Net problem or a Sky Q problem and whether it is resolvable???
Anyone any ideas (in simple terms please!)
Thanks!
Re: Plus Net Wifi Connection problems after Sky Q Installation
04-05-2021 7:00 AM
Thread moved from Fibre Broadband to Tech Help.
Forum Moderator and Customer
