Plex - router switches itself off
Johnbyrne2
When I install Plex I need to switch my router on and off before it will communicate with remote devices. It then works fine until another device communicates with  the router. At that point the link between Plex and the remote devices is broken until he router is switched on and off against. If you are trying to access Plex remotely this isn't much use. Any ideas?
