Pictures Will not upload
- Re: Pictures Will not upload
04-10-2008 12:21 PM
Trying to upload pics(in .jpg) to www.myxpyrenees.com/mypix01.html but nothing's happening.
I'm putting: <img src="vienna002.jpg" width="480" height="360" align="center"><br> but no result.
My ftp is FileZilla.
Anyone help please?
Anyone help please?
4 REPLIES 4
04-10-2008 1:50 PM
its looking for the pictures here http://www.myxpyrenees.com/vienna002.jpg but they are not there
04-10-2008 2:05 PM
To clarify the point Pierre is making.
You have created the html file which looks for the pictures in the same directory as the file is located.
When you say you are trying to upload the pictures are you using FileZilla to upload the pictures as well. If so can you do a screen print of what you see when you use FileZilla to go there
04-10-2008 4:18 PM
Thanks for that. It's sorted now. It was a case of case sensitivity!
04-10-2008 5:17 PM
Been there - done that
That is why I always use lower case
