Photo Downloads
- Re: Photo Downloads
Photo Downloads
10-05-2010 7:25 AM
Regards
timberwoody
[Moderator's note by Dick(Strat) All upper case title and post edited as per forum rules.
Re: PHOTO DOWNLOADS
10-05-2010 8:12 AM
Re: Photo Downloads
10-05-2010 11:39 AM
Re: Photo Downloads
10-05-2010 1:53 PM
Regards
TIMBERWOODY
Re: Photo Downloads
10-05-2010 2:00 PM
Re: Photo Downloads
10-05-2010 2:50 PM
Regards
TIMBERWOODY
Re: Photo Downloads
10-05-2010 2:56 PM
Or open F.F. and go to tools and then downloads then right click and select " open containing folder" to see where they may be
Re: Photo Downloads
10-05-2010 3:45 PM
Quote from: timberwoody I have just downloaded a large amount of photos from e mails...
Do you mean you have been sent emails with photos as attachments? Are you then trying to download them with your email client (e.g. Outlook Express, Thunderbird, Windows Mail etc, if so, which one?) or are you using Firefox and webmail? I think we need to be a bit clearer about what you are doing.
Re: Photo Downloads
14-05-2010 7:31 AM
I have now managed to transfer my e mail photos direct to my PICASA files.
Many thanks for your help!
TIMBERWOODY
Re: Photo Downloads
14-05-2010 2:49 PM
Re: Photo Downloads
18-05-2010 8:04 AM
Regards
TIMBERWOODY
Re: Photo Downloads
18-05-2010 9:27 AM
There is a lot of helpful discussion on this in the Picasa help forum if you are interested in delving a little deeper
Bob
Re: Photo Downloads
23-05-2010 8:02 AM
Regards
Timberwoody
Re: Photo Downloads
23-05-2010 8:45 AM
As far as Picasa is concerned, you might like to start right at the beginning
http://picasa.google.com/support/bin/static.py?page=guide.cs&guide=16027&topic=23911&answer=156338
and move on as and when you feel up to it.
Good luck anyway.
Re: Photo Downloads
26-05-2010 8:09 PM
If you still can`t find the pics you downloaded from your emails..... try this....
START > then type in the name of the file just above the word START.... (start search) and it will, hopefully, find where the pic is located.....
right click on the file that is found and the click on "open file location"
This will then give you where all your other pics have gone to as well.....
