Phonomatic P8 No Drive
30FTTC06
Fixes: 4
Just aquired a P8 Phonomatic which has motor and light working but no drive, the variable resistor seems fine as does the forward and reverse. I'm hoping to find a broken belt or such inside.
Any thoughts welcome please before I open it.
9 REPLIES 9
30FTTC06
Fixes: 4
Re: Phonomatic P8 No Drive
I have tried moving the still Projection switch into both positions as well.
A wild guess.... http://www.ebay.co.uk/itm/EUMIG-P8-PHONOMATIC-8mm-Cine-Projector-Belt-Main-Motor-Belt-/152151353289
@30FTTC06 If the belt's not broken you can put it in a kettle and boil it, this will have the effect of shrinking the belt when cool and you can try it at least before you buy a replacement, but at that cost...
Wouldn't be the first time I've done this to cassette and record player belts in the past, and it worked for me.
30FTTC06
Fixes: 4
the belt is melted away all sticky etc, thanks for the hot tip though
30FTTC06
Fixes: 4
And now the darn lamp has gone.... meh!
What next... Undecided
That looks to be a chunky bulb that I'm sure you'd get an LED equivalent for as the one in the eBay listing appears to be a single pin bayonet cap.
30FTTC06
Fixes: 4
I've ordered one from here which looks to be Halogen, I'm not sure if that will be a bit brighter or not.
@Anonymous  Do you know off hand what type of lamp the old one might be ?
It would appear that I've got it wrong (not for the first time) that's a four bayonet bulb you have there and not the standard I thought it was. Having said that you in theory only need the two bayonets to hold it in. There is dual bayonet one here at half the price but...
http://www.ebay.co.uk/itm/A1-186-12v-100w-Cine-Projector-Lamp-BXT-/160976638035
Does this give you any extra information
https://shop.van-eck.net/SF-0052.html as regards the bulbs it replaces?
30FTTC06
Fixes: 4
It helps to know the 2 pin should fit yes thanks for that.
I think what I was trying to ask is, the old bulb is listed here as Incandescent, and the new bulb is Halogen which should be brighter ?  I'm now thinking that I may have heat dissipation issues etc... It's just an unknown to me. the people who might be able to answer that question have long since departed this world.
30FTTC06
Fixes: 4
As regards your LED thoughts, I guess a 2 pin LED should be possible. I'm also keeping the old cap with the idea of transplanting  a cheap LED lamp into the old cap. I just wanted to get this thing up and running and maybe even try get some footage on a digital camera.
