Pc Upgrade
- Re: Pc Upgrade
Pc Upgrade
03-08-2013 3:23 PM
phenom II x4 955
HD 4890
Asus M5A78L-M/USB3
broke (mobo and gfx card). So I have ordered a few new parts;
FX 8350
HD 7850
Asus M5A99X Evo R2.0
I was happy with my current setup no problems with the games I play and other uses I have for my pc but thought spending a little extra on newer parts would be better. Considering performance previously is this money well spent?
Re: Pc Upgrade
03-08-2013 3:26 PM
Just to add - not only could a PSU fault give those symptoms but - and this is what would really worry me - a faulty power supply could send the wrong voltage down the 12 volt line and fry the GPU and the Modo
Re: Pc Upgrade
03-08-2013 3:29 PM
If you have the opportunity to test the defective parts before purchasing new ones then would probably save you some time and money if they have a strict returns process.
I have been fortunate enough that I keep my parts when upgrading my computers, so if something breaks I would breadboard the computer (strip it to basics) and see what errors the motherboard supplies, I have had a problematic PSU (Power supply) before and I thought it was the motherboard, so just have a hunt around for a old computer that you can plug the power cables in from.
Re: Pc Upgrade
03-08-2013 4:49 PM
Re: Pc Upgrade
03-08-2013 7:12 PM
Re: Pc Upgrade
03-08-2013 7:13 PM
The rest I can't really comment on since I haven't used AMD CPUs since my Athlon XP.
Re: Pc Upgrade
03-08-2013 7:43 PM
Re: Pc Upgrade
03-08-2013 10:04 PM
Re: Pc Upgrade
04-08-2013 1:52 AM
Save your cash for now - you can always upgrade later if you feel it's necessary.
Re: Pc Upgrade
04-08-2013 1:06 PM
