Pavilion dv6 3122sa Failure to start
- Pavilion dv6 3122sa Failure to start
20-11-2013 11:55 AM
My 2 year old laptop by HP has gone into a sulk! It was shut down in the evening as usual but next morning it refused to start. The evidence visible was the Shift Caps indicator lamp was blinking once every 2-3 seconds and the HD lamp was amber. It appears that HP expect to see an error code of 1-8 blinks in a train which is repeated. If that is what I see as a single flash there might be a system failure but the amber HDlamp says that the drive is "parked". The latter suggests that the computer has been dropped which it certainly has not been. Any clues out there?
The HP forum has all sorts of ideas but none exactly what I have, especially the HD lamp, although I have been directed to an HP document giving a re-setting method of fiddling with battery and switch operations which, in my case do not work.
I did raise this problem as a side issue to another problem within Windows but now feel that it was too off-topic there. The laptop is my main machine and its defect is a bit like losing my right hand!!
Re: Pavilion dv6 3122sa Failure to start
20-11-2013 2:16 PM
I would suggest you try again. The procedure seems designed to give the computer amnesia. To make absolutely sure, hold down the power button for a few seconds at the stage when the battery is removed to drain any residual stored charge.
If that fails you will probably have to send it back to HP to get it fixed.
20-11-2013 5:11 PM
You are quite right, I did not quote the reference fully because it was truncated in the post and I did not know all of it. My mind is reluctantly going along the lines that you recommend if no flash of inspiration occurs to someone. I do not hold out much confidence really, I had a paper jam on one of their small photoprinters and their repair qiotation, over and above the cost of sending, was twice the replacment cost of a new one!
20-11-2013 5:19 PM
if you removed the HDD and put it in a caddy on another machine, would it still be "locked" ....
is the system "part of the HDD" or is it in the BIOS on the machine?
22-11-2013 4:01 PM
Your advice has WORKED! I left the machine for best part of the day (doing chores!!) with the battery removed to make sure that there were no odd volts about and then performed the plugging-in procedure as specified and it has booted up into Windows, just as the HP ref said! I am scribing this on it right now. Congratulations.
@ Shutter
I agree that the idea is good,but my machine had sat here overnight on my desk after being closed down and refused to boot-up the following morning! Unless I have an energetic poltergeist I cannot think why it behaved like it did. I did wonder if the HD actually locked mechanically or, as you suggest, the BIOS was involved. I did have thoughts about a suitable caddy for the HD to see if my old Dell could see the contents but this is merely speculation for the moment. Let us hope not to have to put that in action to satisfy our curiousity!!
Thanks to you both!!!
22-11-2013 6:41 PM
24-11-2013 11:14 AM
24-11-2013 11:35 AM
24-11-2013 3:39 PM
25-11-2013 12:09 AM
25-11-2013 10:20 AM
So perhaps if you can get it to start again, uninstalling it might solve the problem?
25-11-2013 3:00 PM
Quote from: ReedRichards Gremlins?
and the best way to fix those, ... is....... ?
27-11-2013 12:29 PM
To be serious, I think Scribe has the right idea. Repeat the 'fix' that worked last time (temporarily) then disable or uninstall the hard drive protection software that is causing the problem to recur.
03-12-2013 3:12 PM
