Passwords relating to Plusnet Webspace
Dreamer
Does anyone please know how to
(a) Change webstats password? In my case it is using an old password, but there is no facility to change that, that I can see.
(b) Change the password on the FTP software that I use to upload files to my plusnet webspace?
When I go on to the remote login, the password used is from an old plusnet pwd that I changed a while back. When I put the new pwd into the FTP software it will not work. I want it to use the new password, same as my plusnet account pwd.
Thanks for your help.
