Partial blue light on Hub Two
louisebeckley
Hi - had connectivity issues yesterday and advised that Openreach would fix remotely. Blue light is back but only partially. Any know what this means? Thanks!
6 REPLIES 6
Fixes: 389
Re: Partial blue light on Hub Two
@louisebeckley What do you mean by 'only partially'? Can you use the internet?
louisebeckley
Just about it’s pretty slow. Assume it’s taking a long time to get fully back up and running. Just wondered if the partial blue light meant anything. Thank you
Fixes: 389
If you have a blue light, your connection is up. I don't use a PN Hub, but I understand the light does not go all the way round.
If your speed is still slow, can I politely ask how 'computer technical' you are, so we know how to frame our help responses?
Assuming a Hub Two the lights are only on the top and bottom of the circle.
HTH
louisebeckley
Thanks everyone. Not overly tech savvy - managed to set it up originally. I think it’s just a bit slow due post the fault. Thanks for the response. Best, Louise.
Fixes: 389
@louisebeckley If I ask you to post a screenshot of this page, obscuring your username, can you do it?
