Pareto Logic
- Pareto Logic
Pareto Logic
02-01-2016 1:37 PM
I am unsure what this is and don't want to click on it in case I cause myself a problem.
Could someone please tell me what this is and if I should click on 'start'?
Re: Pareto Logic
02-01-2016 1:40 PM
I would suggest removing it using Add Remove Programs
Re: Pareto Logic
02-01-2016 10:48 PM
Re: Pareto Logic
03-01-2016 11:05 AM
It is a common rule of thumb in business; e.g., "80% of your sales come from 20% of your clients." Mathematically, the 80–20 rule is roughly followed by a power law distribution (also known as a Pareto distribution) for a particular set of parameters, and many natural phenomena have been shown empirically to exhibit such a distribution.
Re: Pareto Logic
03-01-2016 11:12 AM
Re: Pareto Logic
30-01-2016 9:38 AM
ParetoLogic
Backup
ParetoLogic
Internet Security
ParetoLogic
RegCure Pro
ParetoLogic
PC Health Advisor
ParetoLogic
EasyFileViewer
ParetoLogic
FileCure
ParetoLogic
Data Recovery Pro
ParetoLogic
Privacy Controls
XoftSpy
AntiVirus Pro
Re: Pareto Logic
30-01-2016 11:44 AM
Re: Pareto Logic
08-02-2016 7:24 PM
Re: Pareto Logic
08-02-2016 7:59 PM
Re: Pareto Logic
09-02-2016 12:31 AM
It is possible the startup entry is still trying to start on boot so you'll need to enter msconfig to delete/disable the startup entry for paretologic.
http://www.howtogeek.com/74523/how-to-disable-startup-programs-in-windows/
gtowen
Re: Pareto Logic
10-02-2016 6:05 PM
Re: Pareto Logic
10-02-2016 6:26 PM
Re: Pareto Logic
10-02-2016 10:08 PM
