Page title not displaying and refresh issue.
walkingtape
I getting ready to post update one of my clients website hosted on plus.net... I have an issue in that the page title is not being displayed, its replaced by the domain name which intern means when you refresh a page it goes back to the home page.
Any ideas?
TIA
Martyn
14 REPLIES 14
Oldjim
Resting Legend
Fixes: 63
Re: Page title not displaying and refresh issue.
Can you provide a link to the website
walkingtape
Existing site:
www.gtbunning.co.uk
New site:
www.gtbunning.co.uk/dev
Thanks for having a look...!
Martyn
Oldjim
Resting Legend
Fixes: 63
i am not an expert on Frames which tend to give that result.
The problem I think is that you opening the other pages in a frame on the original site so a refresh will do exactly as you are seeing because the browser only sees it as the host page.
There is probably a way round this and I am sure that someone will be able to assist
Just to add - all the pages have this identical line <frame src="http://www.gtbunning.plus.com/"> or this <frame src="http://www.gtbunning.plus.com/dev">
with no differentiation when you are on a different page of the Plusnet site
walkingtape
I'll have a look at that, got to shoot of to a meeting this afternoon will try on my return, thanks for the help I'll keep you posted.
All the Best
Martyn
walkingtape
Think about it www.gtbunning.co.uk to the root hosted on plus.net so why should this not display the page title?
I'm more on the graphic design side myself Smiley
Thanks again for your time!
Off to my meeting now.
All the Best
Martyn
samuria
The page title is taken from the html <title>gtbunning.co.uk</title> what ever you put there will appear in the top left of the browser is this what you are referring to?
walkingtape
Yes thats correct. I'm using ... <title>G.T. Bunning &amp; Sons Ltd :: Manufacturers of Spreaders, Tankers and Bowsers to the farming industry.</title> on the index page. Its shows up okay when I test locally but not when I post it on the web.
walkingtape
There's also the fact that what ever page you are on when you refresh the page it takes you back to the home page.
Thanks again
Martyn
Fixes: 1,483
This is what is causing the title to be set to that
and the reason why you page refreshes to the same one was answer by Jim
Quote from: Oldjim
You'll need to ditch the frames to sort it.
walkingtape
As far as I'm aware I'm not using frames and I don't set the title to gtbunning.co.uk either.... I'll have another look, thanks for the reply
All the Best
Martyn
Oldjim
Resting Legend
Fixes: 63
From your page
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1"><title>gtbunning.co.uk</title></head>
<frameset rows="100%,*" border="0" framespacing="0" frameborder="0">
</frameset>
Fixes: 1,483
This is a sample of the source the frameset tags indicate it's using frames.
<html>
<head>
<!-- url = http://www.gtbunning.plus.com/ -->
</frameset>
<noframes>
<body>
The website for gtbunning.co.uk can be found by clicking <a href="http://www.gtbunning.plus.com/">here</a>.
gtbunning.co.uk is registered through <a href="http://easily.co.uk">Easily.co.uk - get web site hosting or domain name registration here</a><br></body>
</noframes>
<script type="text/javascript">
var gaJsHost = (("https:" == document.location.protocol) ? "https://ssl." : "http://www.");
document.write(unescape("%3Cscript src='" + gaJsHost + "google-analytics.com/ga.js' type='text/javascript'%3E%3C/script%3E"));
</script>
var pageTracker = _gat._getTracker("UA-229963-18");
pageTracker._initData();
pageTracker._trackPageview();
</script>
<meta http-equiv="pragma" content="no-cache">
</html>
EDIT: Jim beat me...
Oldjim
Resting Legend
Fixes: 63
regarding the title - that only appears in a tab not in the title bar
Midnight_Caller
I know that I am a bit late your Domain www.gtbunning.co.uk is hosted by www.easily.co.uk you need to change the Name servers to:
ns1.force9.net
ns2.force9.net
See How to Transfer a Domain
The frame is hosted by www.easily.co.uk it is a redirect to: www.gtbunning.plus.com
So your new site is at: www.gtbunning.plus.com/dev/ ; I hope this helps.
P.S.
You need to put a alt tag behind the images with a description, to comply with the Disability Discrimination Act (DDA)
