Package priority tool?
breakat
Hi, there used to be a tool on here which i can't remember the name of that allowed users to monitor the packages on their line to see what priority they were being given so as to see if things were working as they should be. I'm having trouble with speed and i'm trying to find this tool again, do you still do it? If so, can you provide a link to it please. Thanks
Fixes: 135
Re: Package priority tool?
You don't mean Wireshark do you?
This Community Library article details it's use http://community.plus.net/library/faults/using-wireshark-for-data-capture/
Customer and Forum Moderator.
breakat
That's it. Thank you.
St3
Aspiring Champion
Fixes: 5
Hey Strat whats that program actully do ? is it worth running just for fun ?
Fixes: 63
Wireshark is a protocol analysis tool that records every packet transmitted by your network card, downstream and upstream. If you are into watching paint dry maybe watching this could be described as fun.  Grin
The Community Support Library article Using Wireshark for Data Capture gives more information.
David
Hey! I find it fun.
Owait...
B.
