PN HubOne and OS X
Fixes: 1,473
PN HubOne and OS X
Whilst using the HubOne some of the older macs started playing up with regard to wifi.
Seems there's an issue where the 2.4GHz and 5GHz both have the same SSID.
Solution seems to be to split them out and then make the older macs connect to the 2.4Ghz only.
Instructions to change it:
Sign into router (192.168.1.254)
Advanced settings
Enter the admin password from the card on your router
Continue
Wireless
5GHz
Sync with 2.4GHz: No
SSID: add a 5 at the end so you can tell the difference
Hit apply
