PITA web browsing, win 8 / 8.1
- Re: PITA web browsing, win 8 / 8.1
06-12-2013 6:09 PM
Since moving to Win 8, I have had a problem of webpages timing out for about 10 tries, then a few minutes later they open with no problem, no particular web pages, just any webpage at any time. I put this down to IE 10. So I switched to win 8.1 to use IE 11 and this had the same effect with web pages timing out. So I went back to Win 8 and IE 10 because IE 11 had a problem with BF4. With a fresh install of win 8 and IE 10, I decided to leave out Microsoft silverlight to see if it would fix the problem of webpages timing out, and it seems to have done the trick, 5 days and not a timed out webpage, (touch wood).
8 REPLIES 8
11-12-2013 4:27 PM
Looks like I was wrong, webpages are still timing out, so Silverlight isn't the problem
I tried to modify my last post, rather than put this at the top of the posts again, but the modify tab wasn't there.
11-12-2013 5:10 PM
Hmm, what's the message at the bottom of the browser when you get the delay (if any)? If it's resolving host or similar it'd seem to be a DNS issue, if it's anything else then either something with the connection or a slowdown on the server you're connecting to (though that's by no means the full set of possibilities unfortunately).
11-12-2013 5:20 PM
Here is what I wrote in another thread Matt,
"This is what I get when the webpages don't want to open, it keeps doing this for a few minutes, then it will start working again, any webpage lse is just an example.
"This page can't be displayed
•Make sure the web address http:// www .lse. co. uk is correct.
•Look for the page with your search engine.
•Refresh the page in a few minutes.
Fix connection problems"
When I click Fix connection problems, it says the website firewall is preventing it, or words to that effect"
Chris, I did a tracert when the page kept timing out and wouldn't let me post and then when it was ok,
Page kept timing out...
Tracing route to plus.net [212.159.8.2]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.2.1
2 13 ms 12 ms 19 ms lo0-central10.ptw-ag04.plus.net [195.166.128.194
3 12 ms 12 ms 12 ms link-a-central10.ptw-gw01.plus.net [212.159.2.15
6]
4 12 ms 12 ms 48 ms xe-7-2-0.ptw-cr01.plus.net [212.159.0.252]
5 12 ms 12 ms 12 ms te9-4.ptn-gw01.plus.net [195.166.129.33]
6 23 ms 19 ms 19 ms gi5-1.peh-cr02.plus.net [84.93.232.61]
7 20 ms 21 ms 23 ms po5.peh-cr01.plus.net [84.93.232.16]
8 20 ms 22 ms 20 ms vlan2658.peh-elb02.plus.net [84.93.232.53]
9 24 ms 59 ms 24 ms portal.plus.net [212.159.8.2]
Trace complete.
When the post had been sent and the page loaded normally..................
2 13 ms 16 ms 12 ms lo0-central10.ptw-ag04.plus.net [195.166.128.194
6]
4 15 ms 12 ms 13 ms xe-7-2-0.ptw-cr01.plus.net [212.159.0.252]
7 20 ms 19 ms 19 ms po5.peh-cr01.plus.net [84.93.232.16]
8 21 ms 21 ms 21 ms vlan2658.peh-elb02.plus.net [84.93.232.53]
9 21 ms 24 ms 20 ms portal.plus.net [212.159.8.2]
Trace complete.
6]
Trace complete.
6]
Trace complete.
12-12-2013 9:10 AM
Hmm. Next time it happens, could you please try a tracert to the affected website and see what happens there?
12-12-2013 2:02 PM
The tracert above was to PN when I was trying to post a reply in the PN forum yesterday Matt, every time I clicked post, the taskbar was a continuing circle, with waiting for PlusNet, then it times out and says the same as above,(replace LSE.co.uk with the PlusNet address).
I tried the Technicolor router you left when you came with Dave incase my Belkin was on its last legs, but the Technicolor does the same. It is not a huge problem, but gets frustrating when I am trying to buy something online and the web page sticks.
Only thing I haven't tried is the TSL and SSL settings in IE. I remember this happening the first time I tried Win 8, and then when I went back to Win 7 and IE 9, I can't remember there being a problem. I would like to go back to Win 7, but Win 8 has all the drivers for my Mobo, plus I don't have to install SP1 and the 3 hours of updates.
23-12-2013 7:39 PM
Now I am getting web pages that are opening with no pictures, just writing down the left hand side of the screen.
Second image is how it should look
23-12-2013 8:02 PM
Have you tried a different browser such as Firefox or Chrome ?
It could also be something as bizarre as a MTU size problem - I had big problems with an email server not so long ago which had a different MTU size to my router.
If it happens on two different browsers (MS and non MS) then do you have access to another machine you can test on ? That would rule out the connection.
28-12-2013 4:10 PM
Thanks for the reply picbits, I tried different MTU settings, with no luck, I did try Firefox a while back but didn't really have it on long enough to remember if it acted the same. What I have tried now is to disable my hardware firewall in the router and that seems to have done the trick. So now I have enabled the router firewall again and input the router homepage web address into trusted sites in the IE security settings and that seems to be working too.
Bottom line is that it seems IE 10 and 11 do not like my router. Belkins are super quick and secure, but maybe too secure.
Edit, I have had to turn off my router firewall again as Web pages were not opening.
