PI zero running hot
Fixes: 15
PI zero running hot
Just put pi-hole on my original zero with heatsink (the free one from the pi mag), and noticed it is running @67C
I had it running on a pi zero w (no heatsink) and it was running @38C, but want the zero W for an other project.
Same sd-card only difference is the zero has a wifi dongle plugged in. Both headless running Jessy (no GUI or hdmi plugged in)
Anybody got any ideas why it is so hot? (top doesn't show any load, 1% running top max, 2 % running htop)
Stats from pi-hole web server
 Active Temp: 63.8 °C
 Load:  0.06  0.06  0.01
 Memory usage:  11.1 %
1 REPLY
Fixes: 12
Re: PI zero running hot
dunno.. but on the pi zero W i got, mine was running at about 40 degrees.
that was with HDMI, and usb ethernet connected, running raspbian stretch lite.
not sure why the original zero would run hotter though.
